Make ModelText not editable
isc01
isc01
I've created a modelText and added it to the document.
How can I make this text "ReadOnly", not editable for the user, so that it can't be deleted and can't be changed?
I tried to set "Pinned" to true, but that still allows the user to change the text.
Thanks for help.
jeremytammik
You could implement a Dynamic Model Updater DMU that reverts any changes the user tries to make to the text:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.31
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
stever66
Is there a reason you can't put the text in a parameter, and then use a label to display the text in the model?
Then you can make the parameter read only.
jeremytammik
That's a great idea!
Jeremy Tammik
The Building Coder
isc01
Thanks!
