Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Loading Revit Add-In into BIM 360
3 REPLIES 3
juanquis_avila
372 Views, 3 Replies
Hi Devs, I hope you all are doing well 😄
I'm wondering if there is a way to load my plugins into BIM 360 in order to use the Add-In in this platform. I'm working with collaborated revit files so it would be easier to run my code on BIM 360 rathen than a local file.
Thank you for your attention 😄
Best Regards.
3 REPLIES 3
BIM 360 is a web platform, whereas a Revit add-in is a .NET assembly executed by Revit.exe on the Windows platform.
Therefore, they are obviously not simply interchangeable.
However, Autodesk has indeed implemented a possibility to access an environment, the Forge platform, that enables you to run your Revit add-ins in a web environment, enabling a tight integration with BIM 360:
https://forge.autodesk.com
So the answer to your questions is:
Yes, you can run your Revit add-in in BIM 360 by converting it to Forge Design for Automation for Revit, or DA4R:
https://forge.autodesk.com/en/docs/design-automation/v3/developers_guide/overview
The Building Coder has discussed some such conversions:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.55
Please address all further questions regarding DA4R to the official Forge help channels, not this forum:
https://forge.autodesk.com/en/support/get-help
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
I've seen a few Revit apps now calling dialogs to list the available Hubs and models, so some people know how to do it, trying for years to do this. Wish I could find a simple example to interact with BIM 360 in a Revit app using Autodesk.Forge api.
Hi @Rockit_for_Revit,
You can have a look at the step-by-step guide on how to create a simple viewer and hubs browser using dot Net or Node Js here. Hope it helps.
https://tutorials.autodesk.io/tutorials/hubs-browser/
  Moturi George,     Developer Advocacy and Support,  ADN Open
