Load Family performance issue
Dear Members,
I am modifying a family and then saving it to a folder. Now till save everything is smooth and fine but when I try to load the family it takes huge time whereas if I load the family via Revit manually its done in a jiffy.
PS: The Revit doc contains 975 instances of the family
Thanks & Regards
Sanjay Pandey
jeremytammik
Please submit a reproducible case including a benchmark with a timer showing how long the process is taking, plus detailed instructions on how to compare it reliably with the equivalent manual process taking less time:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Jeremy Tammik
Developer Technical Services
The Building Coder
