Load Family - Overwrite the existing version
arirobinson
arirobinson
I am trying to load families using the Document.LoadFamily() function.
I have set up IFamilyLoadOptions.
The problem I have is if a family already exists, I want to add types that don't exist but not overwrite existing types.
Currently if the family exists it adds "_XX" to the end of the family name and imports it separately.
I am looking for the functionality of the "Overwrite the existing version" option that is presented in the Load Family button (shown below).
Thank you!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @arirobinson ,
Try using the below code
 familyLoadOption famloadOption = new familyLoadOption();
 doc.LoadFamily(doc, famloadOption);
 public class familyLoadOption : IFamilyLoadOptions
            public bool OnFamilyFound(bool familyInUse, out bool overwriteParameterValues)
                overwriteParameterValues = false;
                return true;
            public bool OnSharedFamilyFound(Family sharedFamily, bool familyInUse, out FamilySource source, out bool overwriteParameterValues)
                throw new NotImplementedException();
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
David_Robison
Have you looked at LoadFamilySymbol()? It will load a single type/symbol from a family.
It requires you to know the name of the type you want to load, which you likely don't have.
I'm not sure if you can open a family with Application.OpenDocumentFile(). If that works, then work through that document to find the type. Load the ones that are missing.
If you can't, you could use Application.NewProjectDocument() to get a document. Then LoadFamily() on the new document to get the family loaded. Then work the the types and load the ones that are missing into your original document.
theknownsilhouette
Hi @naveen.kumar.t
That's insightful. below function from the interface will check if the family is shared or not.
But how can one make a family shared while loading? Is there any other approach where user can decide if a family needs to be shared or not?
