Load Family into family Editor, get bounding box or geometry, Rollback load.
FrankHolidaytoiling
FrankHolidaytoiling
I want to
Is there method for doing this without resorting to placing an instance programatically and using the document changed event? I don't want slow data grab or overly complex code. However if this is the only method, can someone point to the post instructing how to do this?
jeremytammik
I do not see any need to place an instance.
I also do not see any need to roll back any transaction.
You either have an instance, in which case you can use the EditFamily method, or not, in which case you must have something else, which I would assume to be a RFA file, which you can load using the application open document method.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
