Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Live update selected element
3 REPLIES 3
576 Views, 3 Replies
Hello
I'm contemplating a new plugin, and I'm unsure on how to start it.
The idea is that I have a dockable window(already build), and I would like to, whenever I select an element, to input parameters of that element into the dockable window - It would then have to auto-update if I select a new element.
Any pointers on how to do this? I was thinking about MVVM and bindings, but I'm really not a fan of it so any idea that doesn't include MVVM is preferable.
In a regular WPF or windows forms document I would handle a SelectionChanged event and change the dockable window inputs there - is this possible with the Revit API?
Labels (2)
3 REPLIES 3
Moustafa_K
There is a selection changed event see this post
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
in reply to: Moustafa_K
@Moustafa_K Thank you, allthough I’m dissappionted there isn’t a real Call to the API that does this.
i might just try to set it up as a MVVM with bindings to selektion properties instead. No idea if it’s work but it’s worth a try.
Moustafa_K
It should works... I also prefer to use MVVM. let us know the out put of your trials
Moustafa Khalil
Rail Community
