LinkedElement selection returns 2 references
giovannibrogiolo6744
Message 1 of 8
Hi all,
Why when I select an element in a linked files using a selection box I get 2 references with the same Id (instead of 1)?
I am trying to copy/paste elements from a linked file. The command works fine even if the elements are counted twice (i.e. only 1 element is copied into the active project).
Thank you
Replies (7)
Message 2 of 8
caroline.gitonga
Hi @giovannibrogiolo6744 ,
The overload PickObjects Method (ObjectType, String) returns a collection of references selected by the user (multiple selection) which in this case we are using selection box.
A single reference object provides some of these properties:
ElementId -in this case this ElementId refererences the id of the RevitLinkInstance from which selection was done.
LinkedElementId - is id of the top-level element in the linked document that is referred to by this reference.
From my understanding, your selection box selected 2 elements from the same RevitLinkInstance (instance of linked doc).
Therefore, ElementId will be the same for both references and their LinkedElementId should be different.
I hope this explains well. Thanks
Carol Gitonga, Developer Advocacy and Support, ADN Open
Message 3 of 8
caroline.gitonga
I apologize for the above response I posted earlier, I realized it did not address your exact issue. I reproduced the exact issue you are having and submitted it to the engineering team. Will keep you posted with the feedback. Thanks
Message 4 of 8
Thank you Carol.
Are there any updates on this?
Thank you
Message 5 of 8
caroline.gitonga
Thank you for following this up. I have not  received any update yet but I have resubmitted it to the Dev team  for attention.
If I may ask, could there be any specific reason you wish to use the select box instead of PickObjects function to do multiple selection?
Message 6 of 8
I'd like to use the select box because I have more than 10 elements to copy from a linked model and clicking them one by one is a bit tedious.
I have sorted this out by skipping duplicated Ids but I was just curious why this happens and if it's intended.
Thank you
Message 7 of 8
john.miller.DPS
I am seeing the same behavior. I too am curious why this is happening and if there is any update form the development team?
@giovannibrogiolo6744  - out of curiosity, what method did you use to skip over the duplicated IDs?
Message 8 of 8
onBIM-Consulting
I went through the same problem these days. I solved it for now using the LINQ method Distinct( ). Code below:
and here my implementation of comparer
