link up to revit API
Hi all,
I'm trying to link up to the Revit 8.1 Api in a C# environment (express edition 2005).
Can anybody tell me wat's wrong with the following code:
using Autodesk.Revit;
namespace ConsoleApplication1
class Program
static void Main(string[] args)
Autodesk.Revit.Creation.Application revApp = new
Autodesk.Revit.Creation.Application();
thanks for any input,
ruben.
ruben,
All you can do with the API is build a dll with commands in that will be
called from Revit.
I am currently working with a preview of version 9.0 where it is all
documented in Getting Started .doc, but I am not sure what documents were
available with 8.1. (There is no difference in what you can do with the API
though).
Regards
David
wrote in message news:5112450@discussion.autodesk.com...
Hi all,
edition 2005).
class Program
ruben.
Hopefully this is useful: I didn't pay attention to the code in your post (simply b/c I'm a C# code hack and prolly couldn't help you much) but if C# Express 05 is like the other 2005 environments, it won't work with Revit 8.1 or previous. You'll have to wait for 9 for the Revit API to respond to .net 2.0. (unless of course you're using COM and not NET...then I'm double not sure)
Both posters are correct...
1. You can't instantiate Revit from the outside like a COM app - you can only write plugin External Tools accessible from the Tools menu.
2. Revit 8.1 works only with VS 2003. Revit 9, I believe only works with VS2005...
