Line is too short
Line is too short
Message 1 of 11
Line is too short
How do I suppress the error which says can;t be ignored like line is too short.
Thanks & Regards
Sanjay Pandey
Replies (10)
Message 2 of 11
jeremytammik
Dear Sanjay Pandey,
Please take a look at the Failure API:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32
More importantly, please always perform a minimal search before posting questions!
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 11
This is not the first time that I have used the Failure Processing Api. This time the type of severity of the failure is Error can't be ignored. I also Google Searched "Revit Api Failure Processing error can't be ignored" , "Revit API error can;t be ignored" "Revit api handling warnings" but couldn't find.
Before posting I tried:
foreach (FailureMessageAccessor fma in fmas)
   failuresAccessor.DeleteWarning(fma);
and
   failuresAccessor.DeleteAllWarnings();
and
   failuresAccessor.DeleteElements(fma.GetFailingElementIds() as IList<ElementId>);
but couldn't get rid of the dialog "Line is too short. Error can't be ignored"
Thanks & Regards
Sanjay Pandey
Message 4 of 11
jeremytammik
Dear Sanjay Pandey,
Thank you very much for all your research so far.
There was no way to tell from your question that you had explored anything at all yet.
I would suggest that you explore the failure processing functionality a bit further.
I believe that the code snippets you  provide are attempting to post-process.
You can also set up a pre-processor, or something like that, which gives you much more complete control.
I believe, not having done it myself.
I also believe that other previous threads here in this forum do address and resolve similar issues.
Maybe Arnošt will jump in and help out...
Actually, though, taking another look at the links I already pointed you to, I am pretty sure the answer is already given and your research is not yet complete.
Please let us know how you end up resolving this to simplify things for the next researcher.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 11
Sure, I will take another dip in the link provided by you and explore furthur.
BTW a little offbeat but yet. How do I approach Autodesk if I have something developed something substantial.
Thanks and Regards
Sanjay Pandey
Message 6 of 11
Revitalizer
Dear sanjayman,
you can suppress those warnings by avoiding to trigger them 😉
RevitAPI.chm says in the section of the Line.CreateBound method exceptions: "Curve length is too small for Revit's tolerance (as identified by Application.ShortCurveTolerance)."
So just compare the proposed length with that value before trying to create a Line.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 11
pteague
Lol.  Thanks for the in-depth explanation.  🙂
Message 8 of 11
avpBS7DE
Hello Jeremy,
I build curve arrays with points that are unique up to the 9th decimal of a foot (which is the tolerance Revit API uses).
Today I got this error, in a curve array of 8 points/8 edges. These below are my data.
Did anything change in RevitAPI recently to cause this ? (my code has not changed, and was used every day for 2 months)
thank you for your kind response,
Angelo
INFO - sorted points by angle (deg)
INFO - (371.320439699, -78.201695538, 0.526725415) (11.781910)
INFO - (353.310056393, -77.090667510, 0.526725415) (161.274077)
INFO - (349.881316229, -80.166218966, 0.526725415) (180.288841)
INFO - (358.067891914, -80.670617892, 0.526725415) (187.807026)
INFO - (358.067854095, -80.671231706, 0.526725415) (187.815310)
INFO - (366.254391961, -81.176244447, 0.526725415) (345.189149)
INFO - (366.254429780, -81.175630632, 0.526725415) (345.197388)
INFO - (374.440967647, -81.680643372, 0.526725415) (352.661423)
0 -> 1 ((371.320439699, -78.201695538, 0.526725415) -> (353.310056393, -77.090667510, 0.526725415))
1 -> 2 ((353.310056393, -77.090667510, 0.526725415) -> (349.881316229, -80.166218966, 0.526725415))
2 -> 3 ((349.881316229, -80.166218966, 0.526725415) -> (358.067891914, -80.670617892, 0.526725415))
3 -> 4 ((358.067891914, -80.670617892, 0.526725415) -> (358.067854095, -80.671231706, 0.526725415))
error -> line is too short
Message 9 of 11
Revitalizer
as mentioned above,
ShortCurveTolerance 0.0025602645572916664
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 10 of 11
Hi, first of all, you should avoid the errors but if it is impossible, you could use this
This will resolve the error automatically by using default resolution type. In your case it will just skip (I suppose)
Message 11 of 11
klkl12234
Hello. Did you solve it?
I have the same problem.
