make some when element be deselected
Hi everyone
I have a window in my revit addin that has a PropertyGrid which shows the properties of a selected element and can change values. But when I click out of the element (I select a view or I click on the ribbon or menu or I click the Properties window Revit or any node in the project explorer) my PropertyGrid still loaded with information from the last item that I selected.
Is there any way to clean the PropertyGrid when I deselected an item? Or is there a command or option method in the API to do something when an item is deselected or click on another component?
Regards.
jeremytammik
Dear Marcosmateo,
I am not aware of any event being triggered on deselection... nor on selection, for that matter, unfortunately.
However, we did once implement a modeless selection watcher that could be used to implement what you are asking for based on the Idling event:
http://thebuildingcoder.typepad.com/blog/2010/09/selection-watcher-using-idling-event.html
I just notice it was recently reimplemented:
http://thebuildingcoder.typepad.com/blog/2015/03/element-selection-changed-event.html
However, as I have mentioned now and then, use of the Idling event is discouraged for things like this.
You can implement the same thing with an external event instead.
http://thebuildingcoder.typepad.com/blog/2013/12/replacing-an-idling-event-handler-by-an-external-ev...
http://thebuildingcoder.typepad.com/blog/2013/12/triggering-immediate-external-event-execute.html
That gives you more control.
Cheers, Jeremy.
Jeremy Tammik
Developer Technical Services
The Building Coder
