Licensing System Error 1 - Revit 2019 and 2021
terrence.matthews
Autodesk Autodesk
terrence.matthews
Attempted to troubleshoot using the suggested article for Revit 2019
"Licensing System Error 1" when launching Revit or Revit LT | Revit 2020 | Autodesk Knowledge Networ...
Still facing the same error
Also receives "Error 1712" when attempting to use Revit 2021
Please assist
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
So, you cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
