Levels and Elevations questions
1. If I create a Level using ...Create.NewLevel(elevation), it creates a Level with some default X-Y extents.  Is there a way to programmatically change the extents?
2. I can get an Elevation marker (Category = "Elevations"), but I can't seem to get its coordinates.  For example, its Location as LocationPoint (or LocationCurve for that matter) is null.  I can move it, but I want to find its original position first.
Thanks in advance, Chuck
Actually, even if I programmatically move the Elevation marker, the corresponding view plane does not move. (Even though the View arrow moves along with the square Elevation marker, the view plane does not).  Is there a programmatic way to move the viewing plane?  You pick the View arrow to move the view plane manually, but the Location property of this Element is null.  Any thoughts?
Dale.Bartlett
Hi Chuck, Did you ever resolve these points? Dale
______________
Yes, I'm Satoshi.
Dale, I haven't looked for a solution since posting the question, so I don't know if newer Revit API releases can address the problem.
Thanks, Chuck
