Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Level data to datagridview
2 REPLIES 2
vanlion
737 Views, 2 Replies
I have a question how to get data to a winfrom that is using a Datagridview.
I have the following code that is working to collect the Level info, see below:
But how can you simply display the collected info to the Datagridview? because it's not a public value that you can use with
Datagridview.DataSource= levelDataSourceRow
Thanks!
namespace Getlevel
    [Transaction(TransactionMode.Manual)]
    public class LevelInfo : IExternalCommand
        public Result Execute
               (ExternalCommandData commandData,
                ref string message,
                ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            Transaction documentTransaction = new Transaction(doc, "Document");
            documentTransaction.Start();
                try
                    FilteredElementCollector collector = new FilteredElementCollector(doc);
                    ICollection<Element> collection = collector.OfClass(typeof(Level)).ToElements();
                    foreach (Element e in collection)
                        Level level = e as Level;
                        LevelData levelDataSourceRow = new LevelData();
                        levelDataSourceRow.LevelID = level.Id.IntegerValue;
                        levelDataSourceRow.Naam = level.Name;
                        levelDataSourceRow.Hoogte = level.Elevation;
                    using (InfoLevel displayform = new InfoLevel(commandData))
                        displayform.ShowDialog();
                catch (Exception ex)
                    message = ex.Message;
                    documentTransaction.RollBack();
                    return Autodesk.Revit.UI.Result.Failed;
                documentTransaction.Commit();
                return Autodesk.Revit.UI.Result.Succeeded;
2 REPLIES 2
jeremytammik
in reply to: vanlion
Put the data into an intermediary container that you can use as a data source.
Here is a sample that does just that:
http://thebuildingcoder.typepad.com/blog/2012/05/the-schedule-api-and-access-to-schedule-data.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
vanlion
in reply to: jeremytammik
Thanks for the answer a very helpfull example you sent. I also tried the method from the level property sample. This was also doing the job for me!
