Leave winform open when create a new level
vanlion
vanlion
Is have a question. I have a working winform that can create a new level and viewplan. When you press the OK button the winform makes the level.
But is it also possible to let the winform stays open after clicking OK. So you can make a new level again without opening the form again from the ribbon panel.
Maybe something with an event handler?
Anyone with a simple Idea?
Thanks!
jeremytammik
That is a simple .NET Windows.Forms question and has nothing to do with the Revit API.
Yes, you can redefine the behaviour on clicking the OK button, so that the form remains open.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
vanlion
Hi Jeremy,
Good to hear that it is possible and a simple .NET solution.
I searched on the internet but can't find the right function that can do this.
Do maybe have a "google" search idea 😉
The rest i will figure out myself.
jeremytammik
Absolutely trivial, man!
".net redefine ok button action"
https://duckduckgo.com/?q=.net+redefine+ok+button+action
Jeremy Tammik
The Building Coder
vanlion
So simple but it's working very well.
Thanks for the quick response and help!
vanlion
Hi Jeremy,
Last question about this one. The problem to not close the form is solved.
But what code do i need when you press Add, it adds the level to the active document and when you type again a new level name and height in the form it also adds it to the document. So you can make very quick new levels.
It now only added the last given Level
Or do you have to store the new created levels to a list and do a for loop to add them?
This is the last part i try to understand in how Revit handles C# 🙂
