Exporting selected objects to DWG
mhillis
mhillis
Utilizing the API what is the most simple, direct method of exporting selected objects in a given Revit project to a DWG?
Based on the only constructor I see, Document.Export(folder, name, views, DwgExportOptions), I would build a view, isolate my objects in that view, and then just pass that view into the constructor.
By any chance, is there something a bit more direct such as passing in the objects directly for export?
jeremytammik
Dear Mhillis,
Thank you for your query.
Yes, that is the way to go; set up a view and isolate the required elements in it.
That is about as direct as it gets.
The Building Coder presents several samples showing how this can be easily implemented:
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
