Key Schedule + KeyScheduleParameterName + Revit API
gopinath.rajendran
gopinath.rajendran
Is there any way to link KeyScheduleParameterName with Key Schedule in the unique except its' name?
michael-coffey
If I'm interpreting you correctly, you are trying to link the key to the key schedule and it's property ViewSchedule.KeyScheduleParameterName.  You have to iterate the Elements in the model, then check if its OwnerViewId is assigned to a ViewSchedule.  When you have that ViewSchedule, then you can get its KeyScheduleParameterName.
gopinath.rajendran
The elements in the Key Schedule are different from the key parameter which included in the elements.
Keyparam added as a parameter in Door Instance
The parameter element is coming from the key schedule. Is there any access that info directly from  the key schedule
