Join only selected wall and column
I create a simple addin for joining wall and column but it join all wall and column in the active view. I want to join only selected wall and column.It is possible without using inbuilt join button which is in revit?
what changes I want to make in this code?
I using this code: for joining all wall and column
UIApplication uiApp = commandData.Application;
UIDocument uidoc = uiApp.ActiveUIDocument;
Document doc = uidoc.Document;
FilteredElementCollector collWalls = new FilteredElementCollector(doc, doc.ActiveView.Id);
collWalls.OfClass(typeof(Wall));
foreach (Wall w in collWalls)
FilteredElementCollector collColumnsOnThisWall = new FilteredElementCollector(doc, doc.ActiveView.Id);
collColumnsOnThisWall.OfClass(typeof(FamilyInstance));
collColumnsOnThisWall.OfCategory(BuiltInCategory.OST_StructuralColumns);
BoundingBoxXYZ bb = w.get_BoundingBox(doc.ActiveView);
Outline outline = new Outline(bb.Min, bb.Max);
BoundingBoxIntersectsFilter bbfilter =
new BoundingBoxIntersectsFilter(outline);
collColumnsOnThisWall.WherePasses(bbfilter);
foreach (FamilyInstance column in collColumnsOnThisWall)
using (Transaction t = new Transaction(doc, "Join All Walls/Column"))
t.Start();
check = JoinGeometryUtils.AreElementsJoined(doc, w, column);
if (check == true)
else
JoinGeometryUtils.JoinGeometry(doc, w, column);
t.Commit();
It looks like you're using a FilteredElementCollector to collect all the walls and columns and join them all. If you want to join just the selected elements use something like:
ICollection<ElementId> ids = uidoc.Selection.GetElementIds();
ElementSet wallscoll = new ElementSet();
ElementSet colcollection = new ElementSet();
foreach (ElementId id in ids)
Element ele = doc.GetElement(id);
if (ele.GetType().Name == "Wall") wallscoll.Insert(ele);
if (ele.GetType().Name == "Column") colcollection.Insert(ele);
I tried this code but it not working.What changes I want to make in this code and where?
Here is the code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace selection
[Transaction(TransactionMode.Manual)]
public class Class1 : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
using (Transaction t = new Transaction(doc, "Join Walls/Column"))
t.Start();
foreach(Wall w in wallscoll)
foreach(FamilyInstance column in colcollection)
JoinGeometryUtils.JoinGeometry(doc, column,w);
t.Commit();
return Result.Succeeded;
Try changing this:
to this
if (ele.Category.Name == "Columns") colcollection.Insert(ele);
Otherwise can you be more specific about what doesn't work? The code compiles and runs just fine for me on a quick sample project. Have you stepped through the code line by line as it runs to find your specific issue?
