IUpdater throws an exception
abdelrahmanfathe95
abdelrahmanfathe95
I use IUpdater to track added and modified windows to check some rules aganist them, however when I try to open window family document it gives the "third party updater error" and if I try to enable and disable the updater it throws the following exception.
does any one knows what is happening?
Sean_Page
Most likely because the Parameters your checking against aren't "valid" in the Family Editor environment. I typically check doc.IsFamily for most of my updaters because rarely do they like both Project and Family environment.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
