IUpdater throwing error message for users without the plug in
mfalkowski
mfalkowski
I have an IUpdater that is causing a warning on other machines in a Worksharing or Cloud environment.  Originally, I registered the updater onStart-Up and unregistered it onShut-Down.  I realize, in the process of synchronizing, I'm sending this registered IUpdater to all other machines who don't have the plug in installed - hence the warning.
I figured if I simply unregistered it at onSynchronizing and registered it again onSynchronized, I would keep it out of the central model, but that doesn't seem to be the case.
I have two methods..
  • RegisterUpdater()
  • UnregisterUpdater()
I use them in the following events...
  • onstartup - RegisterUpdater()
  • onDocumentOpened - RegisterUpdater()
  • onDocumentSynchronizing - UnregisterUpdater()
  • onDocumentSynchronized - RegisterUpdater()
  • onDocumentClosing - UnregisterUpdater()
  • onShutDown - UnregisterUpdater()
the onStartup call is probably unnecessary, but I thought unregistering it prior to synchronizing would keep it out of the central model, but that isn't the case.
Any advice?
jeremy_tammik
Yes. We talked about that just last week:
https://forums.autodesk.com/t5/revit-api-forum/can-i-come-around-the-missing-third-party-updater-mes...
