Item in frame not appearing in a sheet
Julien.SalleQXGKV
Observer Observer
Julien.SalleQXGKV
Observer
Observer
Hello!
I hope evryone is good,
I made a post because i'm working on a project and i have trouble with element (in the frame) who not appear in one sheet out of 20 aproximatly. It's a localisation plan and when i go in properties, everything is the same.
The good one:
The one who miss localisation plan:
I already try everythings in the properties, and also when i enter in the frame. I'm wondering if I miss something? For me there is no difference between both sheets, that's why it look weard..
I also can make a call and share my screen if it's more simple to resolve problem (because I can't share the file).
Thanks in advance for your help.
Julien
jeremy_tammik
Dear Julien,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Afaict from your description, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface.
So, you cannot expect an answer to a question such as yours relating to product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Julien.SalleQXGKV
Observer
Observer
Thank you very much for your answer, I'm sorry I went to the wrong place.
I wish you a good day,
Julian
