Issues with Viewport.CanAddViewToSheet method
Dear All,
Despite the fact,  all the conditions for view placement on sheet are met, Viewport.CanAddViewToSheet method constantly returns false value;
bool result = Viewport.CanAddViewToSheet(view.Document, view.Id, sheet.Id);
However, if I try to place the view on the sheet without checking whether the view CanAddViewToSheet, everything works fine. I provide the same input arguments in both cases.
Viewport.Create(view.Document, sheet.Id, view.Id, new XYZ(000));
I have seen, that a year ago @Anonymous asked the same question in the post:
https://forums.autodesk.com/t5/revit-api-forum/how-to-add-views-on-a-sheet/td-p/7935024
and was not answered. Does anyone experienced similar issues with this method?
Edit: I use views of ViewPlan class
recepagah12
I tried the same code you provided in Revit 2020 and it returned true. Maybe your file has been corrupted or your sheet, the view has a problem about that method. Can you provide a sample file?
I hope this helps,
Recep.
Here is the file.
Views are placed on sheets only if this line is off: (full code is provided in the macro)
Does anyone?
I was looking for workarounds, and what I noticed is that views that are placed on sheet has the parameter:
'Sheet Number', whilst views that are not placed don't. Do you think this could be a good direction to check whether view is already placed on sheet?
mizrachi_amir2
@Anonymous , 5 years later - did you manage to figure it out?
Speed_CAD
When a view belongs to a sheet Revit adds the Sheet Name parameter, otherwise, when the view does not belong to a sheet the Sheet Name parameter does not exist.
I implemented this simple method to check if it is possible to add a view to a sheet:
private bool CanAddViewToSheet(Autodesk.Revit.DB.View view)
    ParameterSet parameterSet = view.Parameters;
    Parameter sheetName = view.get_Parameter(BuiltInParameter.VIEWPORT_SHEET_NAME);
    return !parameterSet.Contains(sheetName);
 Use:
if (CanAddViewToSheet(view))
    //Create
Mauricio Jorquera
alexander.tomkeyev
Seems like you've passing parameters in the wrong order here. The sheet id should be the second, the view id should be the third parameter.
bool result = Viewport.CanAddViewToSheet(view.Document, sheet.Id, view.Id);
