Issue in importing the revit model
Hi Experts,
920,700 KB is the file size of my architecture model. Is that too large for Revit to accept? i am a new user, trying to convert my revit file into IFC to then pull into Synchro to create a 4D model.  any help would be greatly appreciated.
jeremytammik
The file size should not be a problem.
However, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
For IFC related issues, the Revit IFC forum may be better still:
https://sourceforge.net/p/ifcexporter/discussion/general
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
