Issue in export 2D view from Revit
ritesh.solankeSKPPH
ritesh.solankeSKPPH
I am trying to export 2D view from Revit but I am facing problem while exporting roofplan. In roofplan I can see elements from the floorplan. I have tried checking its visibility,transparency still I can’t get anywhere.
You can see the image's attached below.
        Revit Floor Plan View
                                                   Floor Plan Translated View using Revit SDK
Any help would be great!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @ritesh.solankeSKPPH,
Have you tried using the Underlay Option?
If your Roof is in level 2.
Go to Level 2 and In properties ,set Underlay Range:Base Level as None
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
ritesh.solankeSKPPH
thanks for your reply, but don't need the option in Revit UI but need the option in Revit SDK as I am trying to export 2D view from Revit using the SDK and then writing the SVG file in using my written code. I need understanding on how to get visible element in the code.
naveen.kumar.t
Autodesk Support
Autodesk Support
try using the below link
https://thebuildingcoder.typepad.com/blog/2011/08/set-underlay-display-property-to-none.html
Naveen Kumar T
ritesh.solankeSKPPH
Actually the model we have is central and any changes are not accepted. And plus we have the base level in underlay already set to "none".So any other way round?
