Is there any way to calculate dimension of Area Element?
Hi All,
          As i have used some Areas using "Area Boundary" approach in a revit model. Now i am trying to get maximum allowed/exist dimensions(width/Length) of an area element. Can anyone suggest me any way to do this?
Area element is sorrouned by "area boundary lines".
jeremytammik
Dear Vyom Dixit,
I am not sure I understand your question completely.
However, if the area element is a normal Revit database element, its normal bounding box should give you a rough idea of its maximum width and height.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Yes, Jeremy. You are right. I am asking about Revit Database Area element. As i know, bounding box gives us min/max co-ordinates of 3D rectangular box.
Do we need to trace it's geometry or anything else to get the dimension like length/width/height.
jeremytammik
I don't know. Try it out and let us know how it goes! Thank you.
Jeremy Tammik
The Building Coder
Hi All,
Finally, i got the solution. As suggested by Jeremy, I had tried with "Area" element bounding box co-ordinates and got the success.
Below is the approach i have used to calculate width/length of an "Area" element. Let me know, if anyone find this useful.
Approach :-1. Get the min & max point of "Area" element bounding box.
                   2. Then get respective end points (end points from bounding box's min point  in both the directions).
                   3. Construct a Line by using Line.CreateBound().
                   4. Use length of the constructed line object.
Code :-
public static UV CheckFunctionalAreaDimensions(Element selectedElement, Document doc)
            UV dimension = null;
            if (selectedElement != null)
                Type _type = selectedElement.GetType();
                if (_type == typeof(Area))
                    Area selectedAreaObject = selectedElement as Area;
                    BoundingBoxXYZ box = selectedAreaObject.get_BoundingBox(doc.ActiveView);
                    XYZ targetX = new XYZ(box.Min.X,box.Max.Y,box.Min.Z);
                    XYZ targetY = new XYZ(box.Max.X,box.Min.Y,box.Min.Z);
                    double width = CalculateAreaWidthLength(doc, box.Min, targetX);
                    double length = CalculateAreaWidthLength(doc, box.Min, targetY);
                    dimension = new UV(length, width);
            return dimension;
 public static double CalculateAreaWidthLength(Document doc, XYZ startingPoint, XYZ endingPoint)
            double length = 0;
            Line objLine = Line.CreateBound(startingPoint, endingPoint);
            length = objLine.Length;
            return length ;
