Is there a way to get the currently used character set and character encoding from the Revit API?(2016 or more)
550865615
550865615
For simplified Chinese processing, my plugin always has no exceptions.
But when I worked with the following model, I found that its various names (for example, view names) were all in Vietnamese.
Then, the exception thrown comes from not correctly transcoding the Vietnamese string.
So,is there a way to get the currently used character set and character encoding from the Revit API?Or how can I
convert characters correctly?
jeremy_tammik
Your Revit add-in is a .NET framework plugin. It plugs into the Revit.exe process. You should be able to use standard Windows and .NET functionality to determine the required information from that process. The Revit API does not include any additional functionality in this area.
Thanks for your answer,jeremy.
My plug-in calls an unmanaged C ++ library, and the exception occurs when a managed string is converted to an unmanaged string.
Isn't there any other way?
jeremy_tammik
Sure there are other ways, and they all have nothing whatsoever to do with the Revit API.
https://duckduckgo.com/?q=convert+string+managed+unmanaged+C%2B%2B
