If I write a Revit addin using Revit api 2016 (I mean RevitApi.dl and RevitApiUi.dll in Revit 2016 folder) The plugin does not run without any problems on a system with Revit 2015 installed.
For example I have been developing a revit plugin using the latest version of dll from revit 2016. And I have used several methods and properties that are only available in the latest api version. For example I used somewhere the following code:
Autodesk.Revit.ApplicationServices.Application.IsLoggedIn
This is not available in revit api 2015. So it throws SystemMissingMehotdException.
So How could I handle this if one of my clients uses revit 2015 not 2016?
Do I have to use Revit api 2015 if i want support clients who use revit 2015? Does exist an way to use Revit APi 2016 capabilities in revit 2015?
Thanks for any help.
