How Can i Get Sheet Type and Elevation Option of Sheet
Dear All,
I want to get value of Sheet Type and Elevation option of Sheet. How can i get this.
jeremytammik
Dear Bhola,
Seeing as you appear to be doing serious Revit API programming, I sincerely hope you have worked through the getting started material and installed RevitLookup:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
http://thebuildingcoder.typepad.com/blog/revitlookup
The latter is one of the most important Revit database exploration stools.
It should enable you to easily answer your question yourself.
I hope this helps.
Cheers,
jJeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Dear Jeremy,
you are right. Yes i try to find out this from revit lookup but not get it. Actually i am keen to do programming in revit . I like it most so i am trying to solve issue that raise by some one here or sometime i found from linked in members.
Please give some idea about "Revit database exploration stools" or link from where i can explore this.
Thanks a lot to you .
