Is it possible to create Phases in Revit using C#?
ahmadkhalaf7892
ahmadkhalaf7892
Hello Revit Users,
I have been checking the Revit API , maybe I am wrong but I haven't found a method in which we can Create a Revit Phase Using C#?
1- Is creating a new Phase using the API Possible ?
2- Also How can I set an element to a certain Phase ?
Mohamed_Arshad
HI @ahmadkhalaf7892
       Same threat was already discussed in the forum, There no direct method to create Phase, we have a workaround to create phase. Kindly check the below link for additional reference
https://forums.autodesk.com/t5/revit-api-forum/is-there-any-method-to-create-new-phase-programmatica...
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
jeremy_tammik
Afaik, there is a wish for this in the Revit Idea Station. Please vote for the existing wish to raise its priority.
ahmadkhalaf7892
Hi Mohamed ,
Thanks for the help , I want to be able to create multiple phases within the Revit project but from what I have read and understood my approach is not possible , I will vote to have such a code in the future.
Thanks again
ahmadkhalaf7892
Will do thank you very much
