Is it possible to create a dialog similar to the Warnings' Dialog with the API?
rita.aguiar
rita.aguiar
Hi! Is it possible to create a dialog similar to the Warnings' Dialog with the API?
I would like to create a dialog where I can access data which shows several elements and I was thinking that the Warnings' Dialog could be perfect to display this data and aid the user to show each element.
I know this kind of dialog also shows when you throw an exception here is another image.
Many thanks
RPTHOMAS108
This is more about WPF/Forms in general isn't it?
It is basically a TreeView within a Window. WPF has steep learning curve compared to Forms but it is what they call lookless allowing you to do just about anything visually with a Window.
joshua.lumley
Is this a modeless form? or does it block the user form the model until a button is clicked ?
rita.aguiar
Ohh. I was hoping this dialog was exposed in the API so I wouldn't have to create a similar dialog from scratch with WPF or WinForms.
Thank you for the reply @RPTHOMAS108
rita.aguiar
@joshua.lumley
Yes, it's a modeless form. I was hoping this warnings' dialog was exposed in the API so I could access it real quick and not have to create a similar dialog with WPF or WinForms.
joshua.lumley
Make sure the modeless form is set to topmost.
