Is it possible that when exporting a Revit file to DWG, the linear dimensions will appear in the CAD layout?
jesus.jimenezNLJ96
jesus.jimenezNLJ96
Normally, when I export views with dimensions from Revit to CAD, the dimensions appear in the model space, but it would be convenient if they could appear in the layout without having to do any additional work.
ctm_mka
You want to translate the dimensions from model space to Paper space in, for ease of use, let say AutoCAD (CAD is not a program)? Yes its possible, but would be done in AutoCAD as a post process, not on the Revit side.
mari.shimode
Hi @jesus.jimenezNLJ96 , did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
jesus.jimenezNLJ96
Hi Mari, OK, it wasn't the solution I was looking for, but if there's no other option, I'll accept it. Best regards.
