InvalidOperationException at Parameter.GetUnitTypeId()
jganeshZKVQL
Message 1 of 8
jganeshZKVQL
in our c# revit addin we encountered an error when using Revit 2021 for a code part that works with Revit 2022 without a problem:
private static bool IsValidDoubleUnit(Parameter p)
=> !p.IsShared && p.HasValue && p.StorageType == StorageType.Double && UnitUtils.IsUnit(p.GetUnitTypeId());
The exception throws at calling: p.GetUnitTypeId().
The description says that it is: Thrown if this parameter is not of value type.
Well .... p.StorageType == StorageType.Double ... ‌‌
Is this a known issue/restriction for the handling of the new ForgeTypeId in Revit 2021?
What is the proposed strategy of avoiding this?
Shortened Stack Trace:
Autodesk.Revit.Exceptions.InvalidOperationException
bei Autodesk.Revit.DB.Parameter.GetUnitTypeId()
bei Namespace.IsValidDoubleUnit(Parameter p) in source.cs:Zeile 294.
Thank you for any help!
Replies (7)
Message 2 of 8
jeremy_tammik
What specific parameter are you testing? On which element?
Message 3 of 8
jeremy_tammik
I asked the devteam for you.
Message 4 of 8
jganeshZKVQL
These are the objects printouts:
p
{Autodesk.Revit.DB.Parameter}
    Definition: {Autodesk.Revit.DB.InternalDefinition}
    DisplayUnitType: 'p.DisplayUnitType' threw an exception of type 'Autodesk.Revit.Exceptions.InvalidOperationException'
    Element: {Autodesk.Revit.DB.Plumbing.Pipe}
    GUID: 'p.GUID' threw an exception of type 'Autodesk.Revit.Exceptions.InvalidOperationException'
    HasValue: true
    IsReadOnly: true
    IsShared: false
    StorageType: Double
    UserModifiable: true
p.Definition
    BuiltInParameter: RBS_PIPE_FIXTURE_UNITS_PARAM
    IsValidObject: true
    ParameterGroup: PG_MECHANICAL_AIRFLOW
    ParameterType: FixtureUnit
    UnitType: UT_Number
    VariesAcrossGroups: false
    Visible: true
element
    AssemblyInstanceId: {-1}
    Category: {Autodesk.Revit.DB.Category}
    ConnectorManager: {Autodesk.Revit.DB.ConnectorManager}
    CreatedPhaseId: {372166}
    DemolishedPhaseId: {-1}
    DesignOption: null
    Diameter: 0.32808398950131235
    Document: {Autodesk.Revit.DB.Document}
    FlowState: LaminarState
    GroupId: {-1}
    Height: '((Autodesk.Revit.DB.MEPCurve)element).Height' threw an exception of type 'Autodesk.Revit.Exceptions.InvalidOperationException'
    IsPlaceholder: false
    IsTransient: false
    IsValidObject: true
    LevelId: {-1}
    LevelOffset: -14.555326840290602
    MEPSystem: {Autodesk.Revit.DB.Plumbing.PipingSystem}
    OwnerViewId: {-1}
    Parameters: {Autodesk.Revit.DB.ParameterSet}
    ParametersMap: {Autodesk.Revit.DB.ParameterMap}
    Pinned: false
    PipeSegment: {Autodesk.Revit.DB.Plumbing.PipeSegment}
    PipeType: {Autodesk.Revit.DB.Plumbing.PipeType}
    ReferenceLevel: {Autodesk.Revit.DB.Level}
    UniqueId: "4a32aa57-7137-4718-8e76-63080685d809-0009492e"
    VersionGuid: {0db2d433-fc99-48bc-885d-9184db9efa29}
    ViewSpecific: false
    Width: '((Autodesk.Revit.DB.MEPCurve)element).Width' threw an exception of type 'Autodesk.Revit.Exceptions.InvalidOperationException'
    WorksetId: {0}
Message 5 of 8
jganeshZKVQL
Thank you!
Is it important for me to be able to login there?
Message 6 of 8
jeremy_tammik
No, not important and not possible, either. The link is just for me myself.
Message 7 of 8
david_becroft
Good morning,
Yes, this parameter is of type ParameterType.FixtureUnit. FixtureUnit parameters have an unfortunate combination of properties. They have StorageType.Double but they are not considered to be of "value type", so Parameter.GetUnitTypeId() throws the InvalidOperationException for FixtureUnit parameters.
In the Revit 2021 API, there is no way to directly check whether a given parameter has this "value type" nature, so clients just have to check whether the parameter type is FixtureUnit:
private static bool IsValidDoubleUnit(Parameter p) =>
  p.Definition.ParameterType != ParameterType.FixtureUnit &&
In the Revit 2022 API, aside from the ParameterType enumeration being deprecated, FixtureUnit was retired and replaced with Number. It is safe to call Parameter.GetUnitTypeId() on Number parameters.
Message 8 of 8
jganeshZKVQL
Thank you @david_becroft, this is working well!
I implemented this for the Revit 2021 compile condition only, to avoid deprecation issues in future.
