Inserting single family instance
devX6MRR
devX6MRR
Hi to everyone,
i'm trying to implement the insertion of a family instance from an external library.
When I fire the event to proceed with insertion, I use "PromptForFamilyInstancePlacement" command; this command starts inserting elements till you press "Esc" key.
My aim limitate the insertion operation to a fixed number of instance.
Is there a way to implement this kind of process using "PromptForFamilyInstancePlacement" or any other way without using this command?
Giorgio
matthew_taylor
Hi @devX6MRR,
Check out this sample from theBuildingCoder:
https://github.com/jeremytammik/the_building_coder_samples/blob/706115e03fdac2c586ba0537061cd5dd1ac4...
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
devX6MRR
Hi @matthew_taylor,
I just read your answer and I read the snippet you linked:
the sample is the one we used to start the family insertion.
The problem is that once started insertion till "Esc" pression i can continue insert selected family.
The behaviour is this: i start inserting element -> after first element i escape from insertion procedure.
Maybe in this way is a little more clear my main aim.
Giorgio
matthew_taylor
Hi @devX6MRR,
That is exactly what the sample does. Look at the _place_one_single_instance_then_abort object. If set to true, it should stop after one placement. Check out line 117 onwards.
Cheers,
-Matt
devX6MRR
Hi @matthew_taylor
I checked better the snippet and the only thing i can say is "oh, i didn't notice".
As soon as possible I'll try and I'll let you know.
Thanks a lot,
Giorgio
devX6MRR
Thank you, it fitted very well my problem, I had a little trouble to find missing parts (about Press class and Window Handle), but i found them.
Now it works perfectly.
Thank you again
Giorgio
