Insert Raster Image
Insert Raster Image
Message 1 of 25
Insert Raster Image
How could I insert a Raster Image using the Revit API? In other words, the equivalent of doing Insert>Image
Replies (24)
Message 21 of 25
Wow there are some good ideas here !
Thanks !
Message 22 of 25
Revitalizer
Hi Konrad,
several years ago, I stored multiple images as a base64 coded string in a text parameter (Extensible storage was not available yet at that time).
An approach similar to the one drdanielfc suggests.
One thought:
Just take in account that storing data inside the project file may inflate it.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 23 of 25
jeremytammik
I now migrated EstoreFile from Revit 2014 to Revit 2015:
https://github.com/jeremytammik/EstoreFile/releases/tag/2015.0.0.1
I then migrated it from Revit 2015 to Revit 2016:
https://github.com/jeremytammik/EstoreFile/releases/tag/2016.0.0.0
I hope you find this useful.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 24 of 25
jeremytammik
Published on The Building Coder as well now:
http://thebuildingcoder.typepad.com/blog/2016/02/estorefile-group-preview-and-roomschedulecloud.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 25 of 25
sobon.konrad
Revitalizer,
Of course, you are right, file size is always a concern. I would only say that sheer file size is usually not a big deal and not always an issue with "performance". I am usually concerned about other things when encountering poor performance. On the other hand I would not recommend storing everything inside the model "just because we can", so I just trust that OP realizes the pros and cons of using Extensible Storage.
