Insert Raster Image
Insert Raster Image
Message 1 of 25
Insert Raster Image
How could I insert a Raster Image using the Revit API? In other words, the equivalent of doing Insert>Image
Replies (24)
Message 2 of 25
jeremytammik
Install RevitLookup. Explore the Revit database. Insert an image manually. Check what changed. That tells you what elements were added. Then you can look in the Revit API help file RevitAPI.chm to see how to add such elements programmatically. If you do not have RevitLookup and RevitAPI.chm installed, work through the getting started material first of all, especially the My First Revit Plugin and DevTV tutorials.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 25
RevitLookup is installed, I've gone thru the First Plugin tutorial, and have been writing plugins for about a month now. However, I can't seem to figure this one out. I've found the element in Revit lookup but the information doesn't seem particularly helpful. I also don't seem to be able to find anything relevent in the RevitAPI.chm file. I know how annoying it is when people don't seem to be willing to pull their weight on forums, but I just can't seem to find my way past the first hurdle of what function I would call to create an image. I should be able to figure everything else out thereafter.
Cheers
Message 4 of 25
Revitalizer
Dear drdanielfc,
just use:
document.Import Method (String, ImageImportOptions, View, out Element)
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 5 of 25
How to insert embeded image into revit file ?
Message 6 of 25
Revitalizer
Embedded ?
Embedded into what ?
If it is part of another Revit document, try copy/paste API.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 25
For example. I want add custom image on backgroud of the view. I want that i don't need image file
Message 8 of 25
Revitalizer
yourView.SetBackground(ViewDisplayBackground.CreateImage(string imagePath, etc.));
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 25
I know that . That is not what I want. I want that i don't need external source of image. Because, when I move .rtf file to another computer i also need to move the image file.
Message 10 of 25
Revitalizer
you should better have asked
"How to embed image into revit file ?"
instead of
"How to insert embeded image into revit file ?"
The answer is: no, you cannot embed an image, you just can reference it.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 11 of 25
Thanks 🙂
Message 12 of 25
Is it possible to reference image from web location and how ?
Message 13 of 25
Revitalizer
here is an approach using AVF:
http://thebuildingcoder.typepad.com/blog/2010/06/grabbing-an-internet-webcam-image.html
http://thebuildingcoder.typepad.com/blog/2012/02/revit-webcam-2012.html
Using not the view depending analysis visualization framework but persistent image elements:
Once grabbed and stored the image, you can update an existing ImageType by its Reload() methods.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 14 of 25
is it Possible do something like that.
   String PATH_FILE = "http://net.dd/image.png";
   dispBackground = ViewDisplayBackground.CreateImage(PATH_FILE, ViewDisplayBackgroundImageFlags.UseTiling, UV.Zero, UV.Zero);
I tried. Got file not found exception.
Message 15 of 25
Revitalizer
obviously, you answered your question by yourself.
You cannot.
RevitAPI.chm says:
"Autodesk.Revit.Exceptions.FileArgumentNotFoundException: The file specified by imagePath doesn't exist. "
It seems that Revit needs a valid local file path but not a web URL.
That is understandable:
A web url would be an external resource that would need to be watched by Revit, since it could be temporarily unavailable, could change its content, etc.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 16 of 25
Ok Thanks 🙂
Message 17 of 25
Hi !
Nice ! Thanks ! It helped me !
The function "ducument.import(PathToFile, ImageOptins, view, out Element)" is really usefull !
To go further, is it possible to use "out Element" as a raster image ?
Is it possible to get something like "Element.width = ChosenWidth;" ?
Message 18 of 25
sobon.konrad
Revitalizer,
Would a nasty workaround like this possibly work: you could store the image inside of view as extensible storage (byte stream?) and then in case that file was moved from its original location write a new image to a relative location (from byte stream), so that ViewCreateBackground.CreateImage() method can be executed. Thoughts?
-K
Message 19 of 25
I'm actually doing something similar in one of my add-ins. I store a base64 image string and write it to a temp file for loading. It works fine.
Message 20 of 25
jeremytammik
Dear Konrad,
Yes, absolutely that would work!
In fact, I implemented and published a Revit plug-in that stores and retrieves arbitrary files to and from extensible storage:
https://github.com/jeremytammik/EstoreFile
You should also take a look at The Building Coder topic group on extensible storage:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.23
I just expanded and completed it a little bit, just for this conversation here.
Cheers,
Jeremy.
Jeremy Tammik
The Building Coder
