Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Insert a mass family instance
6 REPLIES 6
467 Views, 6 Replies
I'm trying to insert in a revit's project a mass family instance.
I'm usingg the "NewFamilyInstance" method, after loading the family desired, but nothing happens in the document. It's needed to be bounded? Like I have to do with linear entities?
Thanks in advance,
Natxo
Thanks in advance,
Natxo
6 REPLIES 6
Did you check in the 3-D views if the family instance showed up. Sometimes it doesnt in plan view.
Yes, checked!
Yes, checked!
Yes, I've checked and nothing appears.
You are right about there. Once you create a family family instance(like framing) you have to "bound" it with a line. Sample this:
Dim beam As Elements.FamilyInstance = m_revitObj.ActiveDocument.Create.NewFamilyInstance(pStart, symbol, baseLevel, strType)
Dim beamCurve As LocationCurve = beam.Location '
If Not (beamCurve Is Nothing) Then
Dim line As Line = m_revitObj.Create.NewLineBound(pStart, pEnd)
beamCurve.Curve = line
Yes, I know that the familyinstances must be bounded, but I don't know how to deal with a mass family.
I mean, it's not linear, the Location property return me a LocationPoint, not a LocationCurve.
Moreover, there's no method like "NewLineBound" that works with points, or I've been unable to find it.
Thanks in advance.
Thanks in advance.
I'm terribly stupid, and I must apologize, it was only to activate the "view mass" button!!!
Thanks to all, and sorry again.
