Inheriting FilterNumericEquals and overriding FilterNumericEquals.Evaluate
Hello @jeremy_tammik
Sorry it's a long post but my main questions are numbered at the end.
I was looking at the FilterNumericEquals class and found that unlike other API objects it has a public constructor meaning it can be inherited. Then I look at the Evaluate(Double, Double, Double) method and it has the following note in RevitAPI.chm
"Derived classes override this method to implement the test that determines whether the two given double-precision values satisfy the desired condition or not."
I thought that sounds good because within that method of a derived class I can then convert the doubles to display units and compare them by that. The significance of this is that the epsilon is related to an internal units comparison. So if I wanted to find all lengths of 1000mm within a tolerance of 0.5mm I couldn't easily control that externally. Mathematically I may be able to relate it to that but it seems an obtuse way of going about it. i.e.
0.5/304.8 = 0.00164042
What I find with the FilterNumericEquals is that although you can inherit it the method Evaluate(Double, Double, Double) is not marked overridable. I also tried overloading it and shadowing/hiding it but the derived method is never called.
Then I looked at the class FilterDoubleRule, the constructor takes a FilterNumericEquals and there are the methods FilterDoubleRule.GetEvaluator and FilterDoubleRule.SetEvaluator. However no matter what derived class of FilterNumericEquals you feed into the constructor or with the SetEvaluator the GetEvaluator method always returns the base class FilterNumericEquals (confirming the derived class is never used).
FilterDoubleRule can also be inherited and FilterDoubleRule.ElementPasses is marked with the same note about being overridden in derived classes. Again however the method is not marked overridable.
So the questions I have are mainly as follows:
- Was it intended for FilterNumericEquals class to be inherited and modified?
- If not why couldn't FilterNumericEquals and similar classes have been enum values? i.e. all we seem able to do with them is create a new instance to feed into FilterDoubleRule etc.?
- Would like some clarity on the notes about 'Overriding' the Evaluate and ElementPasses methods i.e. why is this wording within the RevitAPI.chm used if not intended for the developer?
With respect of the original problem I decided to compare double with display units between FilterNumericGreaterOrEqual and FilterNumericLessOrEqual filter rules. I still wonder what to do with the epsilon value of these rules for when the value becomes equal to either the lower or upper bounds.
I should also note that I was investigating these objects with respect to ElementParameterFilter does inheritance of these objects work with ParameterFilterElement (I didn't do any testing with that aspect)?
I found the same issue noted here:
Developer Advocacy and Support +
