Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Indicator for changing Element
I am planning to select 100 elements and then apply the add-in action and change their parameter accordingly.
how do I indicate which element has been change and which has not.
I notice some addin can make the element into white color to indicate the element has been changed.. i search around and i could not find it.
Need help ..>.<
The solution is already given by Jeremy:
http://thebuildingcoder.typepad.com/blog/2011/03/change-element-colour.html
Thanks & Regards
Sanjay Pandey
not about color.. i notice some changes from other addin after they change the parameter. the white colour indicator
for example.
