Independent Tag position
alexpaduroiu
alexpaduroiu
Hello!
I have a problem regarding tags position and I hope someone can help me.
Whenever I successfully create an independent tag for a reinforcement bar, the tag position follows the same transformation I apply to the bar. Lets say for example, if i move my rebar position 3 centimeters in the right direction, the tag position will move the same 3 centimeters in the right direction.
Please let me know if there is a way to maintain the initial position of the tag, no matter the transformation applied to its host element.
The method I used to create a tag is:
IndependentTag crTag = IndependentTag.Create(Document, Document.ActiveView.Id, new Reference(rebar), false, TagMode.TM_ADDBY_CATEGORY, tagOrientation, position);
Thanks.
FlorisvdG
I don't believe you can prevent the Tag from moving.
You can however simply move it back, directly after moving the element.
using:
Tag.Location.Move(XYZ translation);
Where Tag is the instance of the IndependentTag ofcourse.
XYZ here is a translation, so (0,0,0)  means no moving,  (10,0,0) means move it 10 units over the x-axis.
https://www.revitapidocs.com/2018.2/c64687d8-ab52-e36d-a095-2715e5660df6.htm
alexpaduroiu
Well that was a last resort solution. I thought that there can be another way around to hold the position without using the element translation.
Thank you for your answer! 😄
BenoitE&A
Or you can link it to a fixed point rather than your Rebar (the parameter Reference that you use). For this, you can for example create a DetailLine where you want to place your annotation and place it on this DetailLine.
Dirty way, I conceal.
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
