Independent tag Bounding Box getting null for the second time.
praveen.cMXB2H
Message 1 of 11
praveen.cMXB2H
UIApplication uiApp = commandData.Application;
Document doc = uiApp.ActiveUIDocument.Document;
UIDocument uidoc = commandData.Application.ActiveUIDocument;
IndependentTag tag = doc.GetElement(ckt) as IndependentTag;
BoundingBoxXYZ tagBox = tag.get_BoundingBox(uidoc.Document.ActiveView);
//tagBox not null
IndependentTag tag2 = doc.GetElement(ckt) as IndependentTag;
// Same tag (ckt)
using (Transaction trans = new Transaction(doc, "Tag D"))
trans.Start("Start");
tag.HasLeader = false;
trans.Commit();
BoundingBoxXYZ tagBox2 = tag2.get_BoundingBox(uidoc.Document.ActiveView);
//tagBox  null
//With using below code every time getting Bounding Box, but it is generating graphics for every tag and taking long //time.
View sec = doc.GetElement(tag.OwnerViewId) as View;
BoundingBoxXYZ tagBox = tag.get_BoundingBox(sec);
//Is there any other method to get bounding box without generating graphics.
Replies (10)
Message 2 of 11
scgq425
Hi praveen.cMXB2H:
i debug u code in my machine , is right . so u can monitor the result : hasleader or u indenpendtag family
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Message 3 of 11
praveen.cMXB2H
I did not understand , can you please explain clearly.
Message 4 of 11
scgq425
Hi  praveen.cMXB2H:
i use this code in my code ,is ok ,. u can post u file or check the tag.hasleader()'s result
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 5 of 11
TripleM-Dev.net
Hi @praveen.cMXB2H ,
From this line:
This is after you set the HasLeader to false?
Are you using a seperate transaction for each HasLeader change?, this will cause numerous regenerations of the view/model. This would explane the long time processing.
Place all the edits in one Transaction and buffer the Tag elements, then retrieve the view for each element.
I have multiple commands like this, for 1000's elements this runs in under a second.
Also first  check if the leader is actually enabled before setting it to false.
- M
Message 6 of 11
praveen.cMXB2H
using (Transaction rvtTransaction = new Transaction(doc))
rvtTransaction.Start("Move Tags");
IndependentTag tag = doc.GetElement(tags[0]) as IndependentTag;
BoundingBoxXYZ tagBox = tag.get_BoundingBox(doc.ActiveView);
//Getting Bounding Box
rvtTransaction.Commit();
IndependentTag tag2 = doc.GetElement(tags[0]) as IndependentTag;
BoundingBoxXYZ tagBox2 = tag2.get_BoundingBox(doc.ActiveView);
//Getting BoundingBox null
//For the same tag after rvtTransaction.Commit(); Bounding Box getting null
Message 7 of 11
Mohamed_Arshad
HI @praveen.cMXB2H
       I tested you code using Wall Tags, For me second time also it is not null, I think you need to debug complete code and find out the bug or the share the project that you're facing error. So that I can test in my end.
Debug Reference Images
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 8 of 11
ctm_mka
@praveen.cMXB2H As Mohamed stated, getting the tag2 after  the transaction will fix the null issue. The reason, i believe, is in your original code the definition of tag2 is changed so it becomes null, sort of. as for performance issues, why do you need the bounding box of the same tag three times?
Message 9 of 11
TripleM-Dev.net
Propably the HasLeader property is set to False in the transaction. (like in the first code sample)
This could cause the Tag to move to another location that's maybe outside the views bounds, that would explane the geometry issue.
Message 10 of 11
praveen.cMXB2H
Hi @Mohamed_Arshad ,
Please look at the attached sample file for tags. These tags are used to obtain bounding boxes within this file. However, the same tags do not seem to retrieve bounding boxes for larger files. Please review the code as well.
//Sample code
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
IList<Reference> refs = null;
try
refs = uiApp.ActiveUIDocument.Selection.PickObjects(ObjectType.Element);
catch (Autodesk.Revit.Exceptions.OperationCanceledException exception)
return Result.Succeeded;
double ElbowOriginY;
double ElbowOriginX;
double ElbowOriginZ;
XYZ elboworigin = new XYZ(0.0, 0.0, 0.0);
try
try
elboworigin = uiApp.ActiveUIDocument.Selection.PickPoint("Pick the Elbow");
catch (Autodesk.Revit.Exceptions.InvalidOperationException icpointException)
catch (Autodesk.Revit.Exceptions.OperationCanceledException excpt)
ElbowOriginY = elboworigin.Y;
ElbowOriginX = elboworigin.X;
ElbowOriginZ = elboworigin.Z;
foreach (Reference ckt in refs)
IndependentTag tag = doc.GetElement(ckt.ElementId) as IndependentTag;
tag.LeaderEndCondition = LeaderEndCondition.Free;
XYZ baseValue2 = tag.GetLeaderEnd(tag.GetTaggedReferences().First());
double tagBaseX2 = baseValue2.X;
double tagBaseY2 = baseValue2.Y;
if (tag != null)
double A = (ElbowOriginY) - tagBaseY2;
double AngleXvalue = A / (60) + tagBaseX2;
XYZ ElbowPosition = new XYZ(AngleXvalue, ElbowOriginY, 0.000000000);
tag.SetLeaderElbow(tag.GetTaggedReferences().First(), ElbowPosition);
XYZ headerPnt = new XYZ(ElbowOriginX, ElbowOriginY, 0.000000000);
tag.TagHeadPosition = headerPnt;
using (Transaction rvtTransaction2 = new Transaction(doc))
rvtTransaction2.Start("Move");
rvtTransaction2.Commit();
Message 11 of 11
Mohamed_Arshad
HI @praveen.cMXB2H
       As you say code is running without errors at my end, And all tags are obtaining BoundingBox, I don't understand your problem still. And your code is also good.
Mohamed Arshad K
