Can not select any linked element in revit using revit api
jackmrdoctor
jackmrdoctor
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.IO;
[Transaction(TransactionMode.Manual)]
public class FixtureHandOrientationAndLocationCommand : IExternalCommand
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
try
// Get the active document
Document doc = commandData.Application.ActiveUIDocument.Document;
UIDocument uiDoc = commandData.Application.ActiveUIDocument;
if (uiDoc == null || uiDoc.Selection == null)
message = "No active selection available.";
return Result.Failed;
// Prompt the user to select linked instances
IList<Reference> pickedRefs = uiDoc.Selection.PickObjects(ObjectType.LinkedElement, new LightingFixtureSelectionFilter(), "Select linked lighting fixture instances");
if (pickedRefs.Count > 0)
foreach (Reference pickedRef in pickedRefs)
// Get the linked instance
RevitLinkInstance linkInstance = doc.GetElement(pickedRef) as RevitLinkInstance;
if (linkInstance == null)
message = "Selected element is not a linked instance.";
Document linkedDoc = linkInstance.GetLinkDocument();
if (linkedDoc == null)
message = "Failed to access linked document.";
ElementId linkedElementId = pickedRef.LinkedElementId;
Element linkedElement = linkedDoc.GetElement(linkedElementId);
if (linkedElement == null || !(linkedElement is FamilyInstance fixture))
message = "Selected element is not a linked family instance.";
// Check if the fixture has a valid location
LocationPoint fixtureLocation = fixture.Location as LocationPoint;
if (fixtureLocation != null)
// Get the center of the fixture
XYZ center = fixtureLocation.Point;
TaskDialog.Show("Fixture Location",
$"Location (XYZ): {center.X:F2}, {center.Y:F2}, {center.Z:F2}");
else
message = "One or more selected fixtures do not have valid locations.";
return Result.Succeeded;
else
message = "No elements selected.";
catch (Exception ex)
message = $"Error: {ex.Message}";
public class LightingFixtureSelectionFilter : ISelectionFilter
[Obsolete]
public bool AllowElement(Element elem)
if (elem.Category.Name == "Lighting Fixtures")
return true;
return false;
public bool AllowReference(Reference reference, XYZ position)
return true;
i can not select revitlinkinstance that in category "Lighting Fixtures"
if i delete LightingFixtureSelectionFilter() in
it will work find but not what i want. so hard to work with revit link.
the problem is from here
return true;
seem to me revit can not get inside the if statement. even elem have bunch of element in category "Lighting Fixtures"
scgq425
Hi jackmrdoctor:
just implention ISelectionFilter , the input element is revitlinkinstance ,  u selection target category u need to in linkdoc not active document , so u can change u code to this  and run again :
Instance = elem as RevitLinkInstance;
if (Instance != null) return true;
return false;
if (Instance == null)
return false;
var linkdoc = Instance.GetLinkDocument();
var familyInstance = linkdoc.GetElement(reference.LinkedElementId);
if (familyInstance.GetType() == typeof(Floor) || familyInstance.Category.Name == "Beams") return true;
return false;
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
jackmrdoctor
Thank you so much it works.
