In Place Mass voiding solid with no faces
GeomGym
GeomGym
Still looking at extracting geometry from a revit project.
If a user has modelled voids (to cut from a curving wall by face), then a solid reports zero faces and edges.
Here's the code I've attempted.  Can some one please help with how to identify this geometry?
Thanks in advance,
Jon
I don't know if a in-place void does have faces.. When I snoop the void, it also tells there are no faces or edges. What are you trying to achieve ? Do you need the cut-off volume ?
GeomGym
Thanks for the reply.  I'd like to extract the faces (perimeter curves are fine for the time being as the faces are planar) so I can use the geometry in other software.
I hope there is a way of extracting them.
Hello geogym,
I think I've got the solution. I took your drawing and drew a new wall next to it and then used snoop. It new wall had 6 faces and 12 edges. When I snoop your wall it has 9 faces and 18 edges, so the wall itself knows it faces.
So I guess with the example on the wiki you should be able to get the faces 🙂
faces and edges
Joe.Ye
Revit didn't expose the API to read the in-place void family instance.
As Remy pointed out, you can get the consequence of this void in-place family instance by its intersecting wall's geometry.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
