import pointcloud .pts file to revit or convert .pts file to .rcs
04:59 AM
Hi all
I'm makin a Revit AddIn in C#, where I need to import a .pts pointcloud file into Revit. I can't find anywhere a solution to do this, but what i can understand is that the pointcloud has to be .rcs, so i thought that i could find a way to convert .pts to .rcs.
Some old posts in here says that PointCloudIndexer in the Revit Api should do the trick, but apparently it is not available anymore.
Other places says that ReCap is needed for this, but i can't find a ReCap Api or any other help on the net to achieve this.
I did make my code so that i can import .rcs pointclouds into Revit, so i only need help to convert .pts to .rcs.
I hope someone can help?
Best regard
Martin K
Developer Advocacy and Support +
