import adsk file using api
if anyone knows, can someone please provide me the code on how to open adsk file in autodesk revit using revit api?
Dim b As Document
        b.OpenBuildingComponent("C:\Users\Yogesh\Desktop\3760.adsk")
i tried this thing,but it creates erroor
RPTHOMAS108
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
<Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)> _
Public Class EntryPoint_BuildingComponent
    Implements IExternalCommand
    Public Function Execute(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result Implements IExternalCommand.Execute
        Dim IntApp As UIApplication = commandData.Application
        Dim IntBcDoc As Document = IntApp.Application.OpenBuildingComponentDocument("c:\SampleBrick.adsk")
        'Never have I opened one of these and can't find one to open, so can't verify the above.
        'DocumentType Enumeration has a value for this and is avilable through document opening/creating events.
    End Function
End Class
i got the way
Dim
 b As Document
        b = application.Opendocumentfile("C:\Users\Yogesh\Desktop\3760.adsk")
