Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
IFCExportOptions.AddOption
1 REPLY 1
Araa9977
159 Views, 1 Reply
Hello! Where can I find the names of the parameters and the types of values ​​that this method accepts? I exported the parameters Export > IFC > Modify Setup then clicked the Save Selected Setup...' button. Thus, I received a json file, but not all the parameter names are there. Is there a list of options that this AddOption method accepts?
1 REPLY 1
naveen.kumar.t
in reply to: Araa9977
Hi @Araa9977 ,
Please take a look at the below link
https://forums.autodesk.com/t5/revit-api-forum/ifc-export-options/td-p/9686404
Are you looking for this one?
If this is not what you want, could you please explain your issue in detail with screenshots?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Rail Community
