IFCExportConfigurationsMap AddSavedConfigurations not working
david_rock
david_rock
I'm trying to add the IFC Export configurations to my IFC Exporter add on.
However when I use the following code the Saved Configurations are not added.
Using 'C:\Program Files\Autodesk\Revit 2018\AddIns\IFCExporterUI\IFCExportUI.dll' > Not shown at all.
Using 'C:\ProgramData\Autodesk\ApplicationPlugins\IFC 2018.bundle\Contents\2018\IFCExportUIOverride.dll' > Only shown once the File Export IFC command is initialised.
            Dim configurationsMap As IFCExportConfigurationsMap = New IFCExportConfigurationsMap()
            configurationsMap.Add(IFCExportConfiguration.GetInSession)
            configurationsMap.AddBuiltInConfigurations()
            configurationsMap.AddSavedConfigurations()
Any ideas why this is and what I can add to my code to initialise/force the Saved Configurations to display?
Kind Regards
David
jeremytammik
Nope, sorry.
All the real IFC experts are discussing the nitty-gritty stuff in the open source Revit IFC forum, so you might have better luck there:
https://sourceforge.net/p/ifcexporter/discussion/general
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
svein.horve
I was having the same issue and then found this dated post, so for anyone having the same issue I found a solution.
"AddSavedConfigurations()" seems to be using a static property in "IFCCommandOverrideApplication" called "TheDocument" to load the stored configurations. This property doesn't get set until "OnIFCExport()" is called.
Because it's a private property I used reflection to set this property before calling AddSavedConfigurations():
var t = typeof(IFCCommandOverrideApplication);
t.GetProperty("TheDocument").SetValue(null, doc);
formlabKHCQN
Thank you! That was very helpful
