IFC export user defined property sets
chas.barrott
chas.barrott
Hi all....Is there some c# code to export the user deined property sets? The property sets work fine when I export IFC the normal way in Revit but ideally I want them to be exported when using our custom IFC exporting tool. I made an exporter tool which automatically loads familes and makes an IFC of each individual model, hence why I want to use this instead of doing it the manual way.
chas.barrott
Quick update...I managed to find out how this is done, after adding Autodesk.IFC.Export.UI assembly I could get access to all of the IFC export settings and define them as needed. Always more satisfying when you figure it out yourself (google help of course).
BIM.IFC.Export.UI.IFCExportConfiguration myIfcConfiguration = BIM.IFC.Export.UI.IFCExportConfiguration.CreateDefaultConfiguration();
IFCExportOptions ifcOptions = new IFCExportOptions();
myIfcConfiguration.VisibleElementsOfCurrentView = true;
myIfcConfiguration.IFCVersion = IFCVersion.IFC4RV;
myIfcConfiguration.ExportUserDefinedParameterMapping = true;
myIfcConfiguration.ExportUserDefinedParameterMappingFileName = ifcMappingFile;
myIfcConfiguration.ExportUserDefinedPsets = true;
myIfcConfiguration.ExportUserDefinedPsetsFileName = myPsets;
myIfcConfiguration.ExportIFCCommonPropertySets = false;
myIfcConfiguration.UpdateOptions(ifcOptions, view.Id);
doc.Export(folderName, fileName, ifcOptions);
