IFC Export fails
IFC Export fails
ivo.lafeber
IFC Export fails
ivo.lafeber
This is a piece of IFC exporter I use, it used to work, but if we want to export an IFC, the file is or empty or some (only few) of the element's of the 3D view are exported.
When we use the same json with the normal export button in revit it works, but with this code it sometimes works but most of the time not.
When it works in a model, it keeps working in that model, but when it's not working in a model, it's not exporting. so it's a consistant 'bug'.
What can I try to solve this ?
  Using tx As New Transaction(doc)
      tx.Start("IFC")
      If System.IO.Directory.Exists(IFC_Pad) = False Then System.IO.Directory.CreateDirectory(IFC_Pad)
      ' select ifc file
      Dim IFCInstance As New IFC
      Dim configfile As String = Json_Filename
      If configfile.Length = 0 Then
          configfile = IFCInstance.Get_Ifc_Settings_Filename()
      End If
      If configfile.Length = 0 Then Return 0
      Dim ifcconfig As New IfcExportSettings(configfile)
      Dim ifcoptions As New IFCExportOptions
      Dim threedv As View3D
      For Each id As ElementId In Viewlist
          Dim el As Element = doc.GetElement(id)
          threedv = TryCast(el, View3D)
          If Not threedv Is Nothing Then
              ifcoptions.FilterViewId = id
              ifcoptions.ExportBaseQuantities = ifcconfig.ExportBaseQuantities
              ifcoptions.SpaceBoundaryLevel = ifcconfig.SpaceBoundaries
              ifcoptions.WallAndColumnSplitting = ifcconfig.SplitWallsAndColumns
              ifcoptions.FileVersion = ifcconfig.IFC_Version
              For Each item In ifcconfig.Settings_Overig
                  ifcoptions.AddOption(item.Name, item.Value)
              Next
              Dim selectedconfig As BIM.IFC.Export.UI.IFCExportConfiguration = BIM.IFC.Export.UI.IFCExportConfiguration.CreateDefaultConfiguration
              selectedconfig.VisibleElementsOfCurrentView = False
              selectedconfig.UpdateOptions(ifcoptions, threedv.Id)
              Try
                  doc.Export(IFC_Pad, threedv.Name, ifcoptions)
              Catch
                  Debug.Print(Err.Description)
              End Try
              cnt_Exported_Views += 1
          End If
      Next
      tx.Commit()
  End Using
jeremy_tammik
I do not know what IFC might be in this context. Is that a class? It is not part of the Revit API, is it? Is it defined by the Revit IFC open source project? If so, you may have better luck discussing this in the IFC discussion forum:
ivo.lafeber
This is the full class, it's not defined by the open source project.
I only use the the autodesk dll
"C:\Program Files\Autodesk\Revit 2023\AddIns\IFCExporterUI\Autodesk.IFC.Export.UI.dll"
Public Class IFC
    Const IFC_Pad As String = "c:\ifc\"
    Public Shared Function Export_IFC(ByVal doc As Document, Viewlist As List(Of ElementId), ByVal Json_Filename As String) As Integer
        Dim cnt_Exported_Views As Integer = 0
            tx.Start("Kropman_IFC")
            ' select ifc file
            End If
                    Next
                    selectedconfig.VisibleElementsOfCurrentView = True
                End If
            Next
            tx.Commit()
        End Using
        Return cnt_Exported_Views
    End Function
    Private Function Get_Ifc_Settings_Filename() As String
        Dim fd As System.Windows.Forms.OpenFileDialog = New System.Windows.Forms.OpenFileDialog()
        Dim strFileName As String = ""
        fd.Title = "Select Ifc Config File (Json)"
        fd.InitialDirectory = My.Computer.FileSystem.SpecialDirectories.MyDocuments
        fd.Filter = "All files (*.*)|*.*|Json files (*.Json)|*.Json"
        fd.FilterIndex = 2
        fd.RestoreDirectory = True
        If fd.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
            strFileName = fd.FileName
        End If
        Return strFileName
    End Function
End Class
