IFamilyLoadOptions not respected in python
mike
mike
I am reloading families from disk based on a user selection, intending to allow easy updating to standard families.  I want the parameters to remain unchanged, retaining the values set by the user.  My implementation is below.  The parameters are reset to the values being loaded no matter what I do.  Apparently I am in over my head.  I'm using python and the most excellent pyrevit library to run it.  Thank you for your time.
from rpw.ui.forms import (Alert)
from Autodesk.Revit.DB import FamilySource, IFamilyLoadOptions
from rpw import ui, revit, DB, db
import clr
clr.AddReference('RevitAPI')
class FamilyOption(IFamilyLoadOptions):
    def OnFamilyFound(self, familyInUse, overwriteParameterValues):
        overwriteParameterValues = False
        return True
    def OnSharedFamilyFound(
            self, sharedFamily, familyInUse, source, overwriteParameterValues):
        source = FamilySource.Family
        return True
sel = ui.Selection()
newfam = clr.StrongBox[DB.Family]()
if ui.Selection():
    try:
        famdoc = revit.doc.EditFamily(sel[0].Symbol.Family)
        familypath = famdoc.PathName
         famdoc.Close(False)
    except Exception as e:
        print (e)
    if familypath:
        with db.Transaction("Reload Family"):
            revit.doc.LoadFamily(familypath,FamilyOption(),newfam)
            Alert ("Family updated from: {}".format(familypath))
    else:
        Alert ("No External file to reload")
else:
    Alert ("Nothing Selected")
jeremytammik
The IFamilyLoadOptions interface uses a C# `out` parameter to return the setting you require:
  out bool overwriteParameterValues
`out` parameters are not supported by Python:
Therefore, this naive translation of the IFamilyLoadOptions interface will not work as expected in Python.
I would suggest defining your IFamilyLoadOptions interface in C# instead.
Jeremy Tammik
Developer Technical Services
The Building Coder
bhprest
Hey Jeremy.
I'm certainly no expert, but I believe that within IronPython, you can pass an instance of
clr.Reference[T]
to any C# method requiring an out parameter, where <T> is the Type expected back. Once the method returns, you can then use the TryGetValue() method to retrieve the value that was output.
I believe that I've used this within RevitPythonShell before, but a quick search through my personal library didn't yield any examples that I could share.
jeremytammik
Well then somebody might want to check the IronPythonShell wrapper implementation for the methods used above and ensure that the arguments really are passed by reference. Where does this implementation come from?
Jeremy Tammik
The Building Coder
mike
Good idea.  Python is more familiar but I got it to run from a button in pyrevit.  My users will never know.  Nor do they care.  Everything works great IF the family has a change.  If there has been no change, the parameters reset to whatever is in the external family document.  The user has no idea if there is a change or not.  How can abort the insert in that case or test if there is a change?  I'm sure there is something I'm missing here.
tamas.deri
It works this way:
class FamilyLoaderOptionsHandler(DB.IFamilyLoadOptions):
        overwriteParameterValues.Value = True
        return True
    def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues):
        source.Value = DB.FamilySource.Family
        return True
