Identify Import Revit file elements with specific shared parameter in Autodesk Inventor
EhabElsheikh
EhabElsheikh
I want to import Revit file into Autodesk Inventor environment but each element inside Revit file has element ID which I can't change it. also, Revit elements tagged with shared parameters inside Revit, and I want to replace element ID or replaced with specific shared parameter to be bodies name in inventor.
jeremy_tammik
Yes, indeed. The Revit element id is automatically allocated and cannot be changed. If you need to set some data item in the BIM element to correspond to the Inventor body, you will have to use something else, e.g., a shared parameter.
