Export Square image of Current View
dgoff96
dgoff96
I am making a python tool that exports an image from the current view using the ExportImage() method. I have the below code working:
doc = __revit__.ActiveUIDocument.Document
activeView = doc.ActiveView
options = DB.ImageExportOptions()
options.ViewName = activeView.Name
options.FilePath = "path\\test1.png"
options.ZoomType = DB.FitDirectionType.Vertical
options.PixelSize = 200
doc.ExportImage(options)
What I want to do from here is figure out how to force the image to be square? i was hoping for a "Vertical and Horizontal" Fit Option, but that doesn't seem to exist. Any ideas?
sayu94
Hello. I use this lines to get certain sizes
crapai
You can also use a filled region with no pattern and masking turned off.
